Need some info on 6.0 iron block
What is the factory bore? I am looking to order some forged pistons and was wondering what is the factory bore size? My block will not need to be bored so It will probably just get a hone with the new pistons. I also need to know the factory rod and crank dimensions. I already tried to search it and couldn't come up with any thing.
LQ4
The Vortec 6000, or LQ4, is a V8 truck engine. It is a bored version of the Vortec 5300. Displacement is 6.0 L (364 CID) from 101.6 mm bore and 92 mm stroke. It is an iron/aluminum (note that 2000 model year engines had cast iron heads) design and produces 300-325 hp (224-242 kW) and 360-370 ft·lb (488-502 N·m). LQ4s are built in Romulus, Michigan and Silao, Mexico.
