Where can I find a 3 keyway single roller timing chain?
Re: Where can I find a 3 keyway single roller timing chain?
Thanks for the info. I thought all of those hex-adjust type sets were double chain. I'm looking for a simple type 3 keyway single roller or if necessary a single non-roller chain set. If there is a hex-adjust, single-chain cam gear that will work with the stock chain, I'd be interested in that too.
"I went w/a Jwis chain part# : HME-G68VC-60, and Cloyes Hex-adjust gears (single) # CLY-9-3153A. The chain is a true single roller, every bit stout enough to handle 600 + HP. This is the same chain Katech used in the C5 they built to run and win the 24 hours of LeMans. The Cloyes gear set does come w/a chain....but, is basically just a stock chain. The Jwis chain is beefier, and IMO has a better fit. Eliminates all that slop you've got in the stock chain." (orig quote LowETz)
