turbo motor
turbo motor
i want to build a motor that can handle some psi, I have a 98 block and im really not interested in gaining displacement. I'm thinking i should rebuild using old crank and rods and getting new pistons with new rod bolts, etc...
Do a search in this sectoin you'll find alot of info on this. If your going all out and want the most reliable look in to a forged SB from one of the sponsors. After all the machine work, balancing, line hone, all new bearing, and parts is about the same cost. I would also recomend forged rods too. If you just want to slap in some forged pistons and a hone and see how long it will get you that will work too... alot cheaper but not as reliable.
