car dies when coming to a stop
like the title says. when i come to a complete stop the idle goes from about 1100 to 500 then if i dont keep the idle up it dies. Its been doing this for some time. I a MS4 with the LS6 heads & a TSP tune. I replaced the 02's, & the MAF, & the TPS then cleaned out the TB, im thinking its going to be either the spark plugs, wires, or maybe a vacuum leak but i dont know where to start.
Also early in the morning itll i can start it then it dies, start it again itll surge then die. Then about the 4th or 5th time it may catch then stay at about 1100. When i leave for work it drives fine but at times it will drive then feel boggy and if i press the gas it just goes. I really dont think its the tune cause its been fine and just started this around april or so. I have EFI live but have no idea on how to use it and the EFI live site isnt very much help on what to do. So id appreciate any suggestions
thanks
thanks
i replaced the fuel filter about a month ago, and ive never replaced the pump. the pump only makes the initial noise when you turn the key then it goes away after a few seconds.
Did you ever get a real (not mail order) dyno tune?
https://ls1tech.com/forums/showthrea...306&highlight=
After my cam install I got a good tune. We went out for a ride, I was in the passenger seat holding the laptop, he drove and watched the graphs on the screen. He pulled over maybe 4 times and adjusted the tune for my setup at part throttle, full throttle, etc and really dialed it in.
should be i replaced it a year ago when i did the HC install dont know how to test it tho?
i have not tested the FP cause i dont have a gauge where the billet fuel rails are. I never purchased one and now im wishing i did.
It could be an exhaust leak as well but i dont know how to find that either.
As far as the mail order tune, thats all i have. I didnt want to fork out another 500 for a dyno tune. But even after i got the mail order tune the car ran like a champ for months. now its doing this.
Man i need to learn how to multi quote.
i agree, your tune is all messed up; plus its possible they sent the wrong tune file. Contact Charlie@RPM Motorsport; hes the best mail order tuner that can tune anything and get real close without seeing your car. he charges 150.00 i believe.
well if it was the tune and i got that done over a year ago why would it start doing it now. I dont even see how a tune thats in the computer would just go bad. Im going to check the IAC and maybe try looking for a vacuum leak.
LS1 Tech Administrator
Your PCM has learning adaptives. Your short and long term idle trims will eventually try to get your IAC counts where they should be stock. When this happens, you'll have dying and other nasty stuff.
Try this, zero out all L-trims, then start drilling your TB blade or cracking it open until your IAC counts are between 30-60 at idle with the AC off (engine fully warmed up). Once that's done, you can start dialing in your running airflow in gear. Trust me, getting the IAC counts in that range is key to good running.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
pm sent
As Patrick says, there's a good chance you just need to get iac correct. If you have efi live, step one would be set up a scan including iac, throttle position, and stft. You'll have a much better idea of where you and what you have to do.
