ls3 intake question
Old 11-17-2011, 11:23 AM
jeflab's Avatar
Default ls3 intake question
Will an ls1 throttle body bolt on an ls3 intake?
Old 11-17-2011, 11:24 AM
mbaker3's Avatar
The LS1 is three bolts the LS3 is 4 bolts
Old 11-17-2011, 11:28 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
No sir a stock LS1 throttle body will not fit. Like stated by mbaker3 the LS1 tb has 3 bolts to mount instead of the 4 needed for that intake.
Old 11-17-2011, 11:41 AM
jeflab's Avatar
damn, I need a cable throttle body that will work with an ls3 intake.
Old 11-17-2011, 01:12 PM
96ImpalaLT1's Avatar
Me too!!! Who sells them
Old 11-17-2011, 05:40 PM
mbaker3's Avatar
The FAST 92mm Throttle Body works great, but it is a little high $. I just purchase one to go on my LS3 intake with L92 heads.
Old 11-17-2011, 05:45 PM
SweetS10V8's Avatar
I too have run the FAST 92mm on several LS3 intakes, works great.
Old 11-19-2011, 05:44 PM
regblkss's Avatar
I had a Nick Williams 90. That was a 4 bolt cable.
Old 11-19-2011, 07:51 PM
1lejohn's Avatar
The Holly 90 will also fit.
Old 11-20-2011, 06:42 PM
Mike454SS's Avatar
Yeah, unfortunately there's no OEM one from GM that will work. You have to go aftermarket.
Old 11-20-2011, 06:47 PM
Wicked69's Avatar
I just found a UMI 90 mm throttle body that is 4 bolt for $200 in new condition. You can find them but have to be really on the look out for them.
Old 11-20-2011, 07:11 PM
MikeFSKSpeed's Avatar
BBK has an off the shelf 92MM for the ls3 that retails for $319, I can give an LS1 tech discount if interested. It requires the reuse of stock TPS/IAC
Old 11-20-2011, 08:39 PM
82cetuner's Avatar
hey MIKE shoot me a PM what one would cost shipped to watertown SD with shipping and LS1tech discount. I am also military if that helps.
right now I am leaning towards a NW 92 off ws6 store for 329 and probably prefer it over the BBK but if its a good enouph price Il get one from you.
I will have to probably have my mechanic order it for me though since i am still deployed overseas shoot me a PM
Old 11-21-2011, 02:00 AM
pm sent
Old 12-01-2011, 06:45 PM
flywheel's Avatar
Do you need to change to a 24 tooth reluctor to use a cable TB? I'll need a TB for my ls3 intake and would like to go cable...
Old 12-01-2011, 08:30 PM
the_merv's Avatar
I have a Holley 90mm Cable one forsale with Sensors too, aswell as a GM L76 Intake, if interested PM me.
The L76 uses stock LS1 MAP, LS3 is a screw-in.
Old 12-01-2011, 08:54 PM
4doortypels's Avatar
nick williams is a nice piece in my opinion make sure you order a bracket or fab one up... FYI L92 intake has the smaller 10mm map sensor port... same size as ls1 ls2 ls6... plus on the you may need a MAP extension depending on where your orininal sensor is. ls3/l92s work with a 4+ inch bore
Old 12-01-2011, 11:57 PM
chuckd71's Avatar
I'm using one of these to put my ls1 tb on my ls3 intake. Already have my TV cable stuff set up or I'd just buy a new tb. Decent looking piece though I'm not sure it's worth $95. Supply and demand at work I suppose.
http://www.ebay.com/itm/220894278310...84.m1439.l2649
Old 12-02-2011, 12:01 AM
the_merv's Avatar
I bet you choke that motor with a stock LS1 TB.
Old 12-05-2011, 12:18 AM
SSLSXLQ9L92's Avatar
I went with an Edelbrock 90mm on my ported LS3 intake. Paid 250 shipped on here with all the sensors. It looks pretty good.
Quick Reply: ls3 intake question
