Fuel Pump Wire
Fuel Pump Wire
Quick question...
Doing a LY6/4l85e swap into a 67 Olds Convert. I have the donor harness that has been re-worked. I am also putting in a new painless harness at the same time.
The donor harness has a green wire lead to run my fuel pump. The painless harness also has a green wire for the fuel pump.
The painless one is nice, new and part of the rear harness very easy....I would have to splice in and run a new wire on the opposite side of the car to use the PCM/donor harness lead.
Does it matter which one I use???? Any difference???
Thanks.
Thanks.
