Gmpp lsx454??
Gmpp lsx454??
I did a search but wasnt 100% sure. Can the crate motor just bolt into a 2002 Camaro. I know the 58x - 24x Reluctor Wheel Conversion Module will be needed but it is fuel injected and wondered if it can bolt in. Of course intake and other things are needed. Thanks in advance everyone
Providing you're keeping it fuel injected (LS7 intake), yes it will physically bolt in (electronics may have to change a little though, exactly what I do not know). From what I understand, it would be like doing an LS7 swap just with an extra 128lbs, wet sump, and the ability to use all bell housing bolts with either newer or older transmissions. I'm sure there's someone on here who knows more on the LSX block and/or LS7s to give you more insight. Have you checked the Conversions & Hybrids section?
