ls3 376/480 crank pulley seal?
wanting to swap the corvette crank pulley for the truck style pulley to be able to run some hydraulic pumps for an offroad truck (belt spacing). My question is the vette pulley has a rubber/metal seal on the crank end of the pulley and the truck pulley does not. The seal can be removed but will not fit the truck pulley. Does anyone know what this seal is? and do I need it? Has anyone swapped aftermarket pulleys (under/overdrive) did they have the seal?
Thanks
Mark
corvette
Truck
Thanks
Mark
corvette
Truck
I swaped my stock 2010 Camaro crank pulley for a SLP underdrive pulley. The stock pulley has the same metal/rubber gasket as that Corvette pulley. You do not put it on the SLP pulley or I suspect on that truck pulley you are using. Just replace the timing cover seal.
LS1Tech Premium Sponsor
We typically throw them out when swapping the pulley.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
