Cam swap gone bad
Cam swap gone bad
I started out Saturday to swap cams in my car and was making good progress when the balancer stopped me dead. We broke two pullers before I called it a day. Sunday morning I went back at it after letting everything soak in penetrating oil and I finally got it to break loose and it sounded like a gun shot when it let go. Then came the camshaft cover plate that we could not get off. We broke three T-40 tors bits before we got all but one of the bolts out. I guess the engine builder figured they should be thread locked with JB Weld. The last bolt was a pain for about an hour and I finally welded a nut to it and took it out with a wrench. Did I fail to mention that the engine did not have a timing chain guide/tensioner? So after all this I figure I have paid for my sins and the engine should come together quick. We pull the old camshaft and I inspect it before we proceed, yep you guessed it the cam had a damaged lobe. So off with the cylinder heads and now I have a short block sitting in my car. Like the saying goes if you want it done right you need to do it yourself.
Here are some pics.*
