LS2/3 valve cover vent tubes?
So engine is an 08 LS2, but heads, intake & throttle body is an LS3. I went to the dealership to get the vent tubes that connects the drivers side valve cover to the intake behind throttle body for an LS3. The tube has connections on it like fuel line quick connect fittings & fit on tubes like this:
But valve cover has tube like:
So i gather the LS3 valve covers have a different tube than the LS2 does.
Does the LS2 have a plastic tube that runs from valve cover to intake, or is it just a 3/8 rubber vacuum hose.
ls2 valve cover connection
I have a 2007 Corvette LS2 in my mustang and the tube that connects to the intake manifold is plastic with the connector that clips to the nipple the end that connects to the valve cover is a small section of rubber hose about an inch or so long that the other end of the plastic hose connects to.
