Vararam Composite Intake Manifold For LS3 Based Engines
I am going to have to redo my "truck" accessory drive package in order for this intake manifold system to fit. I think I will go with the Holley style. This of course depends that the thing pans out like it should.
I'm thinking someone misunderstood. Perhaps they meant that indeed it would fit an ls1 cathedral port but didnt put it together that the fbody cowl is so low. Finally it makes sense to me though because I was looking at it and my fast 102 barely clear my cowl so I had serious doubts about this clearing lol
The Scammer Hammer
The Scammer Hammer
I'll call back Monday and try to get some clarification. I PM'd twice and haven't received a response yet.
#34
The Scammer Hammer
From speaking with Patrick about it, it seems at WOT they're actually seeing 102-103 kPa on tests, which speaks volumes for cylinder pressures and getting the wave dialed in right, if that makes sense.
Brien, if you haven't done so yet, pick up the phone and talk with Patrick about it. It's REALLY neat all the attention to detail that went into this thing. A lot of little tricks and whatnot.
When I grab one of these, even though mine will be square port, I'm gonna have a buddy with an FBody come over and yank his intake off and see just how much if any height restriction there is.
#35
UNDER PRESSURE MOD
Bingo.
That's like meeting a hot chick, and she tells you all the things she wants to do to you, then finding out she was once a dude.
#36
In some of the pictures I saw it was actually shaped somewhat like a "Y". See attached picture. I also think that would be the better design. The dyno testing they are doing will tell the tale.
On the whole I like this design a lot better than the MSD Atomic Air Force. This one has a nice smooth path for the air to flow to the runner bellmouths which in turn are pretty straight into the head ports.
With the MSD it appears to look like a bread box with the air inside going every which way depending on which cylinder is drawing the air and on which bank. Again, the dyno will tell the tale.
#37
Location: Coast of San Mateo County Between Pacifica & HMB
^^^AGREE^^^ that eyeballing the VARARAM looks to be smoother
Airflow vs MSD, Anxiously awaiting results.
Would like to test all 3 including (FAST W/ Race & Mid Runners) on my Big Bore TFS LS3, CAMMOTION LLR 396" @ 7000-7500RPM!
Looking for 650+ Crank HP!
#38
Talked with Patrick 2 weeks ago and indeed the "T" was only temporary and was replaced with a "Y". With this design largest gains will be realized with higher flowing LS3-LS7 rectangular ports limited by 'oem-like' intake manifold architecture. For those of us with ported or aftermarket cathedral port heads, something may become available later....
#40
UNDER PRESSURE MOD
I'm going to say no. Look at how high above the valve cover it is, and how far back it is. Now look at your engine bay and look at how much room there is above the top of the valve cover in the back.
I will say though, you could probably get it to fit with some trimming of the cowl, and dropping the k-member down.
