How bad is this timing chain
Old 05-14-2015, 07:47 PM
itsdaveonline's Avatar
Default How bad is this timing chain
I assume this timing chain is pretty much toast? Or can i adjust it with the guide? I assume that's a no since it's not a tensioner of sorts?
That explains all the slack feeling on the crank when trying to remove the crank bolt...
Any way i can get the new chain on without messing up that pesky o ring gasket everyone keeps talking about? If i for sure have to remove it a p/n for that gasket would be great if you guys have it.
Thnx
Dave
Old 05-14-2015, 11:44 PM
Whoops can someone move this to internal engine
Old 05-22-2015, 12:32 PM
joenub's Avatar
if you are referring to the oil pump o-ring, then no. the oil pump is in front of the lower timing gear.
Quick Reply: How bad is this timing chain
