Fast 102 MAP
Old 07-28-2015, 12:25 PM
KH504's Avatar
Default Fast 102 MAP
I'm getting ready to put a Fast 102 on my 2002 Firehawk. What are you guys doing with the MAP in the back of the intake? I know there are a couple of different options, I'm just trying to see what is the best one.
Old 07-28-2015, 12:29 PM
Exidous's Avatar
Stock MAP in the back works. That's the standard option. Do you have a specific question?
Old 07-28-2015, 03:22 PM
redbird555's Avatar
it didnt work on mine and for a lot of other people. on some cars 50-50 shot the map will contact the firewalland break off after some use. dont mount it on the front though as the ls1 maf doesnt work as well in that area.
i simply got an npt hose barb and threaded it into the map port on the rear, then ran a 8" piece of hose to the mapand just zip tied it to the harness. the best part about that is it makes removal much easier since you can actuallly reach the maf with the intake installed
Old 07-28-2015, 08:24 PM
KH504's Avatar
thanks for the help.
Quick Reply: Fast 102 MAP
