Need help with DBW setup
Greetings all,
Have a 2006 LS2 from a Trailblazer SS. I'm using the stock ECM (E40), stock DBW throttle body, but I don't have a pedal or any other part of the DBW system. I read the E40 doesn't utilize a TAC module so all that leaves is the pedal with the sensor, right?
Is there a part i can buy from a parts store like gmpartsdirect or do I have to go diving and hunting for a 2006 TBSS pedal? Or will any pedal from a E40 ecm vehicle work?
Please help me verify what I need
Thanks
Thanks
I'm in a similar position but I got rid of my factory harness & ECM. I'm going to go with PSI for their hotrod harness & all other components. He sells pedals so give him a call and he will get you in the right direction.
BTW mine is an 07 tbss and it does use the external TAC and like you I didn't even think to ask for the pedal when I bought my complete pull out swap, I was way to excited !
Tony
Tony
