Abear Motorsports now offering Award Winning rocker covers!
While we were at SEMA '07 GM presented us with their 2007 SEMA Design Award for Best New Accessory.
You folks there might have noticed GM had a set of our Enclosed Coil Rocker Covers installed in the LS7 powered H3 at their booth.
In case you're not familiar with us we offer a 2-piece rocker cover that hides the stock ignition coils from view while allowing you to retain stock length plug wires.
Here are a couple shots of a set installed in a GTO:
Corvette and an F-body:
Pricing can be found on our website www.AbearMotorsports.com Please contact us anytime for more information.
Thanks,
Thanks,
I have a set that I bought and I think they are great I want to have something engraved on it now can that still be done??? One problem I have encountered with them is the extremely tight fit in the f-body cars on the passanger side where the heater hoses are anything being down to address this or any suggestions??
i am planning on getting them with my plate name on them but ran into a little money problem i almost have the money again i hope you didnt bump up the price b/c of the award! lol
We use one 3/8" hose barb fitting on the passenger side which easily hooks to the PCV system, on the driver's side there is a GM PCV valve plugged into the lid of the rocker cover. This also has a 3/8" hose barb fitting which some of you may or may not need. It caps or plugs easily if thats the case.
As for F-bodies, you often need to file or grind some material off of the heater box to make the pass side fit without rubbing.
