need advice on heads..
Old 03-25-2009, 10:39 PM
maynard89's Avatar
Default need advice on heads..
I have a question about heads.. i have a 99 LS1 with a MS4 cam with supporting valve train, a Fast 90mm intake and a 90mm throttle body, little to no exhaust, and I have a Nitrous Dave's wet system(stand alone fuel cell with C16 in it) set up for 150 shot. Which is fantastic btw, thank you Chris at Dave's for all the help..And I have the lingenfelter two step that allows me to take time, and i have it set up to take 8 degrees of time out, when on the bottle. I have spoken with people at Texas Speed and they are trying to sell me the 5.3 heads, i am afraid that with the raised compression that i could have issues with the bottle and would maybe not get the best results considering the size of the cam.. the LS6 head sounds like a good deal too But i im not sure what head i should get. any suggestions, or comments??
Old 03-25-2009, 10:41 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
they make the heads...they sell/make the cam....they sell lots of comp products....what would you have a problem with? they know your setup better than YOU do by now.
Old 03-26-2009, 12:40 AM
maynard89's Avatar
so in other words, just take their advice and don't ask questions right?
Old 03-26-2009, 08:38 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
no, ask questions, but still...they sell this setup prob every day. there know this setup well. if they did not think that it would help you, i do not think they would offer it.
Old 03-26-2009, 09:00 AM
sroach20's Avatar
nitrous likes compression.
Old 03-26-2009, 03:45 PM
maynard89's Avatar
alright, thanks guys.5.3 head it is then.
Old 03-26-2009, 04:13 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Sorry I missed this one. As stated, nitrous does like compression when you have the right fuel supply and timing for it! What short-block are you running? With that cam, you'll be smacking valves to pistons with these heads on a stock shorty and no valve reliefs. With valve reliefs, you're golden and the 5.3L head will be nice because of the compression bump due to those smaller chambers. of course, the LS6 heads will work very nicely as well if you have valve reliefs, you just have to mill them a bit more to get that compression!
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-26-2009, 04:22 PM
jmill96Z's Avatar
I have a similar setup with a decent sized cam and 5.3 heads. I have -4cc Mahle pistons and have no PTV issues. Mine does OK for what it is.
Old 03-26-2009, 04:32 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Werd!
Old 03-26-2009, 06:30 PM
maynard89's Avatar
Why would it be an issue with the LS6 combustion chamber, i have the stock LS1 heads on it now, and have no valve clearance issues. are they not the same combustion chamber size.. it is the factory short block..
Old 03-27-2009, 02:11 PM
Jason 98 TA's Avatar
You might also consider the new PRC 215 heads, we can set you up with smaller chambers for a compression bump while keeping good piston to valve clearance! typically we've been seeing 480-500rwhp with heads cam MS4/PRC 215 combos!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Quick Reply: need advice on heads..
