cam choices
cam choices
What is a good cam for an LS1? Im looking for strip and strip with a good to fair idle. Im using the stock heads and manifold. I have a diablo sport tuner, 80mm BBK throttle body, 85mm SLP mass air, and a K&N cold air intake. I was looking at comp cams XR265HR, part number 54-412-11. Any suggestions?
LS1Tech Premium Sponsor
LS12Fast give us a call, I'm sure we can help spec a custom grind exactly for your combination. I've done a few stock manifold camshafts including one in my wife's 35th anniv. SS Give us a call & we can help you out, I bet I can even find the before & after from installing the 220R in her car.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
