I have 2 stroker cams, witch one ??
I have a Ls2 418 right now ,But going to start a new build with a LS3 block. Im thinking of a 427= 4.100" stroke & 4.80" bore or a 433= 4.100" stroke & 4.100" bore. The cams that i have is a, Cam Motion 257/266-.646/.622.(.665/.640)-114 and a Crane 250/266-.631/.631 (.650/650)-112 . I will run a little nitrous also. So witch cam is the best to my setup. Ill be running the top end in my sig. Both cams lift is calculated with 1.7" & 1.75" rocker arms
