What are all the parts i need to order to mount a oil pan to shortblock for 06 GTO
Old 04-23-2009, 03:28 AM
BigRich954RR's Avatar
Default What are all the parts i need to order to mount a oil pan to shortblock for 06 GTO
Ok building a whole new engine again.
Short block done oil pump/cam and covers are on . ordering 06 GTO oil pan and what else do i need to order so i can mount the oil pan ?
Where to buy from and what part numbers?
Old 04-23-2009, 08:46 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
you will need the pan gasket and pickuptube with o ring and possibly windage tray. If the engine has a longer stroke, you may need to shim the windage tray. We have all of that stuff readily available.
Old 04-23-2009, 12:59 PM
Thank you
Should i put any RTV on the gasket when installing ? Should i use locktight blue or red?
If anyone has any pics they would like to post of how windage tray, oil pickup tube should look installed i wouldn't mine ?
Old 04-23-2009, 05:05 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
You should not need any of that. These gaskets are not like old school small block chevys.
Old 04-24-2009, 10:51 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
bro if you need a oil pan give me a call, I have a new one you can have for $125!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Quick Reply: What are all the parts i need to order to mount a oil pan to shortblock for 06 GTO
