couple LQ4 questions.
installing a LQ4 into my 2000 SS, the LQ4 came out of a 07 silverado 2500. I was wondering if the reluctor rings were the same? if so can i use the lingenfelter module to convert the signal to the pcm from 58 to 24? also, im going to be putting the flywheel on it that is the oe from my LS1, will it work properly with the 6.0?
