Oil cooler fittings - urgent help required
well, am building a custom twin oil cooler system and installing them instead of the foglamps, with a design of either:
1- Engine >>> cooler 1 >>> cooler 2 >>> engine.
or
2- engine >> cooler 1 >> engine
& engine >> cooler 2 >> engine
HOWEVER, im concerned, I got two identical properly sized oil coolers, with the only difference of the fittings. One has a -10 an fitting and one a -8 an and im kinda confused which one to go with.
engine is a high boost twin turbo warhawk, oil used is either 10w-40 or 20w-50 ill have to decide depending on engine oil running temps and thus pressure etc...
or
or
or
Or whats the dimensions of the cooler. width x length x thickness
