want to make 440ish cam only and all bolt ons 03' C5Z any advice?????
Please give advice, and if you have acheived this or close to it, if so what is your set up?
It will require as much bolt ons as you can find. Ported fast 92, ported ls2 tb, electric water pump, under drive pully, cold air intake, I would do lg pro long tubes and they're big 3 exhaust, along with a really heathy cam and good tuner to tune it. It's doable. I would try doing it with out the electric water pump 1st then if your a few hp shy bolt one on but for not much more money you can buy a budget set of heads that will get you about 30rwhp. It would definately be easier and more streetable if you bolt on a good set of heads as well. There are a lot of good heads at reasonable prices out there. Like prc ls6 heads from TSP. Just my .02
