LS2 timing chain dampner or not?
I took mine out, because i run a double roller timing chain. It works fine with the chain, BUT when i went to change the cam, I could not get the chain off the sprocket or remove the damper, When i unbolted the sprocket from the cam the sprocket would not drop down low enough to remove the chain. I had to take the oil pump off to get to the damper bolts out. With a single chain there might not be a problem, but with the duel chain it a pain in the ***.
The original LS1 engines had it although it was made of stamped steel and had clip on plastic guides, this design did not make it past the bean counters and was deleted for production. In 1999 we started breaking chains in the Motorola cup engines when the right circumstances presented themselves, the fix was the dampner to stop the chain whip that was caused by crank deflection. If you can keep it in your engine it will not hurt you, and might help you quite a bit.
Kurt
Kurt
