Intake question !!?
Yeah, the intake will bolt right up to the heads, but you will need injector spacers to run the ls1/6 fuel rail assembly if thats the route you're going - I believe they are something like $10. Also, if you switch to a cable-driven throttle body you will need to get an adapter bracket. I'm actually selling a ported LS2 intake manifold right now if you're interested in solid gains over the stocker.
