LS2 turbo build on budget
I need help building a LS2, so far I have a bare block with stock crank, eagle H Beam rods and Wisco forged dished pistons. I have a good connection at the dealer so i want to use as many factory racing parts as possible. The heads are hand ported 243's with patriot gold kit. Bbk ssi intake and throttle body. Looking at caddy racing lifters and a ls9 cam. Its all going in a 98 z28 with a rear mount turbo GTS T76 and front mount intercooler
It sounds like you have everything you need. What kind of advice are you looking for?
Honestly the best advice you could probably get is going to the FI section and doing searches for similar combos.
