What can I expect from an LS2 Trickflow heads and cam? Anyone done it here?
I wanted examples of LS2s with Trick Flows heads and Cam What can I expect as far as HP and ET? In My case I have all bolton except under drive pulley. (i will afer H/C) Please post any results, Videos, time slips, dyno sheets what ever.
Thanks in advance.
Here is a good one from Fran at Race Proven Motorsports
http://www.youtube.com/watch?v=Tdx3pkEKgzI
Thanks in advance.
You will get 70hp or so depending on cam. When I added afr heads over stock and a slightly bigger cam over the cam I had,I went from 11.7 to 11.1 in the 1/4mi. You should be in the same range. My bud has 500hp on a 383ci with a low 240ish cam,trick 215 heads,non ported fast,no e.w.p and crap old style slp headers. Goodluck to ya. Nice video too.
Thanks for the reply sir. I decided to go with the TF 225s my cam is in that range. Im hoping for 505rwhp or so. My Fast 92 is ported so is my TB. Water pump should help too!
Thanks Ill be sure to post my results and videos and Time slips!
Thanks again
Mike
Thanks again
Mike
