Mast Motorsports cam vs. comp cam for LY6
I just got a LY6 and im wanting to keep VVT, and send my factory harness and ecu to speartech.Cam and springs is the only real mod im doing. has anybody used the mast cam and can give me some feedback on it? and give me advice on which company to go with?
ok so i just called comp and mast and here are the 2 cams they suggested. the specs on the mast cam are 218/230 .564 .578 116 and with the matching springs and cam phaser limiter it is $785. the comp specs are 222/236 .566 .578 114 and with all the same stuff totals up to be $720. whats yalls opinion?
1 Post
Whoever does your cam, ask to see a dyno sheet proving what they are spec'ing for you does what you want. My camshaft spec'd from a member on this forum was a dud. It is a good amount of time and money that you only want to spend once.
where the specs incorrect? an incorrectly installed cam will cause any motor to be a dud, if the cam came with a cam card, it would have provided info to correctly install it or if anything was ground wrong. the degree wheel will verify and find if anything is out of whack.
