combo help
combo help
I'm in the process of ordering parts for my 408 stroker project. My question is can i run a 3 bolt cam with the proper timing set? I know that l92 setups usually have a single bolt cam. and how many teeth do i need on my reluctor wheels with an ls1 pcm?
The combo:
Lq9 block bored .030 over
callies compstar crank
callies 6.125'' h beam rods
diamond pistons
patriot stage 3 l92 heads
thunder racing t-rex cam
The combo:
diamond pistons
LS1Tech Premium Sponsor
I believe the Trex is always cut on the standard 3 bolt cam core, but you might verify that with TR. You'd just need the 3 bolt cam gear, which can be purchased as a set or alone if you're going with a single roller. Yours will be a 24X reluctor wheel.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
