HELP > looking for water pump for car-style intake on TBSS
Hey guys, does anyone know where I can pickup a water pump that will work with my LQ9 408 stroker in a TBSS?
Basically the LS7 throttle body gets in the way. We already have an adjustment bracket for the idler pully, just trying to find a water pump that will work.
I tried meziere and Street and Performance and no luck. They recommend fabrications and possible spacers...
We tried a GTO water pump as well.
If you have truck accessories then you'll need a truck style pump....there's two styles that I know of for trucks...one has a short straight neck and the other has a longer curved neck...the longer curved neck works better cause you can twist it around...PT.net should has more insight on this....
Another option is the Nick Williams DBW TB, which uses the earlier stepper mounted on the opposite side (check your alternator clearance).
