Can I reuse my timing cover gasket?
LS1TECH Sponsor
You probably could re-use them if you are careful, but why is the question. For the small cost of gaskets why reuse them, knowing you won't have to pull something apart to fix the leak is worth the slight added expense. We replace all gaskets when something comes apart just for the peice of mind.
