Ls2 cam only numbers??
OK, guesses? thoughts?
car is a 06 Vette z51. (LS2)
Modds
American racing 1 7/8th headers, high flow catted X, and Magnaflow rears. (I have the off road on now)
Blackwing, Tune.
About to do...
Underdrive Pully, and a Vengence Racing VRX5 cam. (.236/.238 .601/.605 113 LSA)
what you think it will make?
Modds
Blackwing, Tune.
About to do...
this setup is a buddy of mines here in birmingham, its pretty wicked, 470rwhp/436rwtq LS2 GTO with a FTPerformance cam, pacesetter headers, Spintech catback and Xpipe, Fast 90 intake, Patriot gold dual valve springs, Spec 3 clutch, B&M Shifter, Henson Performance tune, Underdrive pulley, and a Vararam Intake, heres the youtube vid of it on the dyno http://www.youtube.com/watch?v=MEs7fC9EkWY
completely stock heads never been off, the only real internals it has are patriot gold valve springs and the cam, thats it, the car is a best, TJ @ FTPerformance out of bham specd the cam and did the install, james henson tuned the car
there hoping for a lil more when he gets the throttle body ported and a pump, the injector are at 95% right now so its pretty close to being maxed on the stock fuel system
I made 480/453 on SNL's dyno with my cam-only setup. That was with everything you could bolt-on except a UDP, plus a light weight flywheel, Monster level 6 clutch, fresh Tick T56 (micro-polished), and a single pice CF drive shaft. With the mods you listed, I would expect 440-450hp at the wheels. There are a few GTO's that have made 460+ on reputable dynos with the right combo.
check this out, buy a 102 fast for $825 delivered then sell your stock LS2 intake all day long for $350...you pay $475!
I am in the same boat as you, I have the money together for a cam kit with premium parts + the money for the install & tune and can't seem to find the extra moolah for the intake...........yet
Thats a good point, BUT i dont have the extra 425 either right now. but it will be the next mod!
I can ge tthe intake cheaper that that too. so it should be a little less.
