LS2 timing chain?
Old 03-17-2010, 01:35 PM
pontiac's Avatar
Default LS2 timing chain?
Ok back 7 years ago i ran a cam in my TA, and had the stock timing chain. it still running today at 135k in it (cam was put in at 42k)
about to put a cam in the vette, and did niot even think about not using the stock timing chain, until i ran into a thread with it. some use it and some saw buy aftermarket?
My vette has 33k on it now, should I use the factory LS2 chain?
People use to put the LS2 chains on there ls1's back ni the day though.
Thoughts?
Old 03-17-2010, 03:40 PM
Petraszewsky's Avatar
I'd say the stock LS2 chain is fine...I used a JP Billet chain instead of my LS2 chain..It is a good idea to get a new chain when upgrading cams since the chain can stretch over time and throw you off when degreeing the new cam..
Off Topic: Where in huntsville are you located?? I'm from the Toney area...Building a house out in Madison now though...
Old 03-22-2010, 08:42 AM
pontiac's Avatar
I am of winchester road. Used to have a black TA that was prtty wel known around here.
Quick Reply: LS2 timing chain?
