Cam Spec Suggestions
Old 05-11-2010, 10:41 PM
NASTY98TA's Avatar
Default Cam Spec Suggestions
Hey everyone I am looking for cam spec suggestions for my new street build.
I am looking to hit the 500+ rwhp mark while keeping good street manors.
Here is the spec of the motor
-aluminum block 408 set for 11.6:1 compression
-317 Heads porter/polished with 2.05/1.60 valves
-LS6 Intake with porter/polished Throttle body and 42 lb injectors
-I am running a built 6-speed
let me know what you guys think
Brian
Old 05-11-2010, 10:50 PM
Wnts2Go10O's Avatar
with small cams making obscene power these days...
have you checked out thunders stroker cam in the dyno section? for an off the shelf cam its a killer and would probably put out some monster torque with your setup.
it may be a bit big for you but your 408 would soak up the cam a lot better than the 383 it was in.
if you want a perfectly tailored cam, talk to patg or call one of the vendors and they will get you squared away.
Old 05-11-2010, 10:55 PM
Mac 2002 SS's Avatar
G5X2 232/240 .595/.608 112 or 114 lsa
G5X3 2xx/2xx .600/.610 112 or 114 lsa
Futral Motorsports F-14 Cam 232/234 .598/.598 114 LSA
these may all be "off -the-shelf cams" , but i would like to think that they all would work nice in a strocker motor.
i don't know why LG Motorsports didn't print the duration for the G5X3 cam ,but i would like to think they would tell you if you give them a call .
Old 05-11-2010, 11:18 PM
NASTY98TA's Avatar
I had a similar cam to the G5X2 for my blower setup, to bad I sold it..
Old 05-11-2010, 11:19 PM
NASTY98TA's Avatar
Default cam
I have to check it out
Old 05-11-2010, 11:32 PM
NASTY98TA's Avatar
That cam is tough!!!
Old 05-14-2010, 07:25 PM
NASTY98TA's Avatar
Default Cam
Well finally ordered up a cam.... we'll see what happens...
Quick Reply: Cam Spec Suggestions
