Rocker arm help
Old 08-17-2011, 12:22 AM
afastm6's Avatar
Default Rocker arm help
I changed my stock rockers to 1.8 roller rockers now im doin a cam swap and they to big I have stock ones that r low miles I just dont know there position to reinstall will this be a problem
Old 08-17-2011, 07:02 AM
ShoddyHog's Avatar
Yes. If you don't know the position to install rocker arms, that will be a problem.
Old 08-17-2011, 02:11 PM
afastm6's Avatar
If u dont get them back on the same valve they were mounted on what does it affect and if thats the.case how can ppl run used rocker arms
Old 08-17-2011, 05:14 PM
crainholio's Avatar
Your wear pattern match between the old rockers and your valves was destroyed when you installed the new rockers anyway. As long as the old rocker pads and your valves are undamaged, it should be safe to reinstall them. Use assembly grease on the valve tips and pushrod ends to protect them during initial startup.
