Do these prices seem pretty accurate for an ls2 bottom end build?
Old 08-18-2011, 11:45 PM
dstappity's Avatar
Default Do these prices seem pretty accurate for an ls2 bottom end build?
Having my Ls2 block rebuilt for a turbo setup, If you see anything im WAYY overpaying for let me know. this is a list for just the bottom end
cam is going to be a custom grind
MACHINE WORK:
Bore and hone with plate- $200 -Without plate- $150
Deck- $100
Balance $150
clean $40
cam bearing install $20
O-ring block $100
Hard Blok (half fill) $180
Assemble $300
Check clearance $50
Turn and polish crank $120 ( if needed, included in price)
Total = $960 no assembly/ $1260 assembled
PARTS (Internal block)
Clevite H Rod bear. (speedinc) $70
Clevite H Main bear. (Spedinc) $100
Cam bearings $90
Camshaft $400 (optional) incl.
Pushrods $140
Trunion upgrade $140 (optional) incl.
Katech (con. rod bolts) $200 (optional) included in price
Arp (con. rod bolt) $100 (optional) not included in price
Oil pump HV $180
Pistons w/ring kit $700
Rods $600
Total= $2820.00
Gaskets
O-ring (pick up) $8
Cometic 4.030 hedgskt $150
Oil pan gasket $40
Valley cover Gskt $25
Timing cover Gskt $25
Rear main seal cover gaskt. $25
Front crank seal $25
Rear main seal $25
Total= $323.00
Grand total- $4403
I rounded up the prices on the parts lists to account for taxes/shipping
Old 08-18-2011, 11:51 PM
icen's Avatar
this is the quote for my 402 build:
Here is the quote , I put together 3 different options. 1 is using your block ,forged pistons,and rods stock cubes. 2 is your block fully forged 402 cubes. 3 is whole new block 402 ci.
1. Forged pistons, h beam rods with arp rod bolts,stock crank and block . This includes all machining and short block assy 3000
2. Forged pistons, h beam rods with arp rod bolts,and forged 402 stroker crank. Includes all machining and short block assy 3850
3. Forged pistons, h beam rods with arp rod bolts,and forged 402 stroker crank. Includes all machining and short block assy New block and ARP main studs 5100
All 3 setups Include new rod,main,and cam bearing. Moly piston rings.
Here are the options for the heads
1.Use stock heads clean, 5 anglevalve job, deck, setup valve springs, and dual 675 springs with titanium retainers,7 degreee locks 700
2. New stage 3 ls6 heads with 2.05 intake valves and 1.60 stainless exhaust ,675 springs with titanuim retainers 1950
Here are the rest of the parts that we will need with whatever short block and heads you go with.
Timing set- cam ,crank,and timing chain- 189
Hv oil pump 209
Custom ground camshaft 420
HP lifter set 235
Arp head studs 289
Complete gasket 265
Hardened pushrods 110
Oil and filter times 2 and coolant 130
Rand R engine 1500
CLean all parts,covers,oil pan,and install heads 550
hope that helps
Old 08-19-2011, 12:21 AM
dstappity's Avatar
The top number one will be my setup, my block, forged rod and piston, stock cube or 369 may be new cube.
Did that quote in your #1 include all gaskets also? and how did you get it done for $1000 less? was yours half filled, etc.?
I will be using factory Ls9 heads.possibly with upgraded trunions and def. valvesprings, etc. otherwise untouched.
Old 08-19-2011, 12:44 AM
Sawzall and Welder Mod
Whistler's Avatar
Some of the machine work seems on the less expensive side of average.
Decking and balancing tend to be a little higher from my experiences. Especially if thats a stock LS2 crank which will likely need slugs to balance the aftermarket rotating assembly.
$300 seems cheap to put it together especially if the rings need to be file fit. Hopefully they're not going to rush anything for you in the name of not working for $15 an hour
Old 08-19-2011, 01:19 AM
Captain Double Post
BOBS99SS's Avatar
yeah if that place is any good those are some fair prices imo, i called around awhile ago to get some price info, and they were alot higher than that for sure
Old 08-19-2011, 12:05 PM
icen's Avatar
no that was just for the shortblock.
Not filled
Quick Reply: Do these prices seem pretty accurate for an ls2 bottom end build?
