swaping engine
Old 09-16-2011, 02:45 PM
bugy's Avatar
Question swaping engine
i'm planning to swap ls1 engine from my camaro 98, putting in a L92 6.2L, what do you think?, will ecu work with it? what else will be needed?
Old 09-16-2011, 03:16 PM
odarabla's Avatar
No, the computer will not work because you have a 24 tooth reluctor wheel and that engine has a 56 tooth. There is a lot that you will need to make this build work. New cam sensor, cam sensor extension, cam gear, front cover, knock sensors, knock sensor extensions, lifter trays etc..
Old 09-16-2011, 03:34 PM
87silverbullet's Avatar
58 tooth to be exact. Call TSP they will set you up with everything to do the conversion.
Old 09-16-2011, 07:12 PM
bugy's Avatar
well, i've heard about a kit or something to make this set up regarding the reluctor wheel, i suppost with it, my ecu would be useful.
Quick Reply: swaping engine
