#7 bent spark plug electrode???whats wrong?
Old 10-12-2011, 04:17 PM
silverLSWON's Avatar
Default #7 bent spark plug electrode???whats wrong?
i was driving my car the other and when i pulled into a parking, my car started popping really bad...when i started looking into it i found that the number 7 cyl spark plug had a bent electrode with ONE tiny little nick on it. the nic is the size of the lead in a mechanical pencil. i put new plugs in, pulled the valve covers to check for bent valves, broken valve spring etc...all that seems normal and functions properly. i then started put everything back together and started it. at first everything seemed normal but once it warmed up a little bit, it had a very faint knocking noise...and some blow by from the oil cap/fil...other than that the motor is smooth and is normal...did i break a ringland on a piston or spin a bearing...ive heard bad ros bearings before and they were way louder..the knocking noise from cold started ls1's were louder than this...just looking for someone who's had simlar issues...i know i have to pull the head off and prob rebuild the bottom end...my oil pressure is great...mods are in my sig
Old 10-12-2011, 04:45 PM
RAMPANT's Avatar
Sounds like it could be a busted up ring land.
Do a leak down and it should be pretty obvious if you can hear air coming out the oil cap.
Old 10-15-2011, 04:32 PM
RENE'S RAGE's Avatar
Sounds like a ring land. I'd pull the head, had the same thing happen to my last motor.
Quick Reply: #7 bent spark plug electrode???whats wrong?
