LS3 and prc stage 2.5 5.3L heads?
I am in need of a new shortblock and am debating my options.
I am wondering if I can use an LS3 block in my current setup or not? I have a set of PRC stage 2.5 5.3L heads and a custom cam right now in my LS1.
Thanks!
Thanks!
Actually I'm running a L92/LS3 block on mine. I threw a rod on my LS1 and brought the heads over to the temp build. I got mine setup for boost hence the lower numbers. Those heads will be the restricting factor for the CI. Relocation of cam sensor to front, requires a harness adapter, relocate knock sensors to side, LS2 timing cover, LS2 valley cover.
