rod/ main bearing clearnces?
what are the clearances supposed to be for the mail bearings? the rod bearings? stock LS2 engine. crank has been turned .010" due to a spun rod. I know on the LS1 the main bearings should be set between .0017"-.0019". Is the LS2 the same?
