ls2 vrs ls3
ls2 vrs ls3
Ok fellas what is the biggest advantage of going with a ls3 vrs the ls2? this engine will have stage 1 prc ls6 head on it. I have yet to spec a cam I kinda wanted to wait till i got the short block at my house. but the idea is to run boost so far this is where im at.
Yeah...stock LS3 heads are pretty dam great compared to older GM castings.
The difference from say the LS6 to the LS2 wasn't as big a deal...they went up 0.3 liters but they used the same heads on the new engine that they used on the old one...when they went to the LS3, they opened up the bore even further, which really helps flow a lot, then they completely changed the port design...which really helps move a good bit more air. LS3 ports almost look like they're stolen from a big block.
i did the opposite of what most are telling you and was happy with the results. i used my prc 5.3 heads that i allready had on top of a used stock bottom end l92. i think the 126 traps for a 3700 pound car were decent for the money spent.
well i do agree the ls3 heads are much better but this is what i have for now. I will buy a forged bottom end ls3 short block and use my heads and intake till i save up more money for the better heads and intake.
im going with a forged bottom end ls3 and will run my prc heads till i save up for some prc ported ls3 heads i plan to run the kypt turbo kit on the car as well.
You are correct. I think we are looking at 11.46:1 with these 62cc 5.3 heads. I did exactly what the op is doing. Use what we had at the time and save for better heads down the road. It still should be a solid setup.
