timing cover and oil pump clearance with double roller
Old 03-07-2012, 07:47 AM
scooter k's Avatar
Default timing cover and oil pump clearance with double roller
I have a TSP LS6 oil pump. I've clearanced the cover and it still hits on what looks to me like reinforcement ribs on the cover of the oil pump and right where the front seal stop is in the timning cover. Thetiming cover in that area is already thin so I'm thinking of taking some off the front cover plate of the oil pump. Is this something that will be fine or cause issues?
Old 03-07-2012, 09:05 AM
scooter k's Avatar
Well that won't work because those aren't reinforcements they are passages stamped into the cover.
Old 03-07-2012, 03:00 PM
65SSZO6's Avatar
If I remember correctly, you can replace 2 or 3 of the upper hex head bolts on the oil pump with flat head allen bolts and you will not need to do any grinding/clearancing on the timing cover.Hope this helps.
Old 03-07-2012, 06:51 PM
mebuildit's Avatar
I used ARP bolts for my TSP oil pump with an Edelbrock 2 piece cover. I did however have to machine out 4 spots on the cover to clear the bolts. No big deal since I have a mill in my garage.
Old 03-07-2012, 07:05 PM
Pumba's Avatar
Why are you using a dual row timing chain?
The best LS timing chains are single row.
Old 03-08-2012, 01:19 PM
scooter k's Avatar
Bolts are clear. I'm really close though at the front cover of the pump and where the front seal stop is in the cover.
Quick Reply: timing cover and oil pump clearance with double roller
