Our builds in my Workshop . LSX , BBF , RHS etc.....
Hi , What's up buddies , Well i like to share you guys our achievements in Kuwait racing , We're not the best but when we built the customers always won
Follow us https://www.facebook.com/wsseven
Alright first we have two cars for our shop
First car is Mustang LX has Big block ford 632ci and 1000 of nitrous in 3 stages , Best time 4.5 . ( this car for drag strip only )
Second car is 2001 Trans Am has LSX 454 high CR , Solid roller , two stages 500hp , full suspension , RPM trans T56 , Dana S60 rear end with chrome moly driveshaft
We're building the car and engine right now and hope will finish less than two weeks ( this car for street race )
So we built these engine below for our customers
When we get this LS7 it was stock , We installed Total seal rings , Clevite H series bearings , Replaced rods bolts to ARP , Changed exhaust valves , installed cammotion and springs , We changed those parts because the customer want to spray 200HP
this motor installed on 2002 SS camaro and put down 540rwhp N/A
LS3 stroked 429ci has 4.070 bore , 6.125 , Stroke 4.125
LS3 stock heads
Bullet custom cam 112LSA
Put down 515-525rwhp N/A . 800rwhp with 300 shot
We built 3 of those engines with same parts 2 of them Almn and 1 iron
RHS tall deck , 491 ci 13:200 cr , Mast 302 heads LS7 , Bullet cam 114LSA , Hyd roller , Put down 660rwhp N/A , 1050-1100rwhp with 400 shot .
LSX 441 , All pro heads ,Solid cam , dual foggers stages , carb , Dry sump , CR 14 , best time 8.6 with one stage
LS3 416 500rwhp
LSX 461 tall deck solid roller with mast heads high CR 850HP
RHS 441 , Mast heads , should make at least 580rwhp in a C6 ZO6
We have a lot of engines on the stand should be done in couple weeks waiting for their parts to arrive
Building powerful racing engines . Bennett Ford 471 . Bennett Ford 434 . LSX 441
Other pics ford engines and others
parts for LS1 sleeved 427 made 540rwhp
Our custom cams
471 ford
440 bennett
Ford 347 , Low compression for Turbo setup
LS2 shortblock STD
Ford with blower for street
Heads
gapping rings
I'll post our next builds as we finish with results , If you guys have questions please feel free to ask
Thanks in advance
LS3 stock heads
LS3 416 500rwhp
Our custom cams
471 ford
440 bennett
LS2 shortblock STD
Heads
gapping rings
Thanks in advance
