Ls2 with ls3 heads mill question
LS1Tech Premium Sponsor
.030" will be tight, but with GM valves in the heads you SHOULD be good to go. As always, be sure to measure to be sure!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The extra .010" of clearance will help for sure.
__________________
