main bolts/arp main studs
I've had conficting statements from 2 differnet machine shops so I'd like to get this sraight
I have forged Gen IV 6.0 that Im assembling
will be running twin turbos 700-800rwhp threw a stalled 4l80e
I currently have stock main bolts/studs and an align hone was done with them
One shop is telling me that I can reuse the stock main bolts/studs and would need an align hone done again if I changed to ARP
The other shop is telling me the stock main bolts/studs are TTY and cannot be reused but I would NOT need an align hone done if I install ARP
Thanks
Thanks
Anything special you have to do when honing an aluminum block with steel main caps? My machine shop is leery to hone them, because the block is aluminum and is softer than the steel main caps. I have a thread in the GEN III internal section. Input wold be appreciated.
https://ls1tech.com/forums/generatio...ing-mains.html
Kenny
Kenny
I have never saw a line hone in action but when it does it hones out the mains so am I to assume that the hone just rides in the bore and is not not fixed in the same position just kinda "floats" in the mains to get them round? and that normally the block is upside down when you hone them?
I just did an iron 6.0, bought the summit racing block (recon'ed 2004+ block) came with stock main bolts, swapped over to ARP and the machine shop mic'ed everything and it was good. Same machine shop did my 3.905 LS1 aluminum block and it definately needed to be honed.
You may or may not need to line hone after ARP studs. Torque them on and measure the bores for out of round. Sometimes they need to be honed and sometimes they don't.
The shop I'm working with likes to line hone all LSx blocks because they've observed many are not straight from the factory. But since yours has already been line honed, I would put whatever fastener in there, torque it down, and check for roundness to see if it needs it again.
