199-PRC Deck Thickness
What is the deck thickness on the 199-Prc l92 heads. My car for some reason keeps trying to lift the heads if u spray over a 150 shot. I used arp head bolts but not studs. Im thinking about upgrading my l92s which one should i go with.
416 ls3, fast 102, T/S 1.7/8 headers. T/S Cam. 11:1 comp
Would like to spray 250 shot without having any head problems.
LS1Tech Premium Sponsor
If you are looking at our aftermarket casting PRC 250cc heads, they have a 3/4" deck thickness.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
You shouldn't be lifting heads at that HP level. I would switch to studs but we have sprayed 250 on bolts before with no problem. Is you timimg high?
The 199-prc is the heads i have now. was thinking about changing them up.
What is the stock l92 deck thickness? I would keep them if head studs would cure my problem but im not sure.
GM head thickness is at or just a hair shy of .500". I would be suspicious of the block's surface finish RA, gasket selection, timing/tune-up, a number of things in the combo, etc before worrying about the heads thickness at that power level though!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
