Is this a good cam for a DD?
Old 08-26-2012, 05:35 PM
Slash8915's Avatar
Default Is this a good cam for a DD?
My friend owns a performance shop and he works mostly on vettes. I asked him to spec out a cam for my C6 Z06 that will produce good power along the other mods he's doing, but still drive like stock. This is what he came up with. I was hoping for a lower LSA so it will sound very lobey at idle, but he said they can tune it to sound lobier. Anyways, what do you think?
231/246 .653”/.652” 115LSA +3 advance (with 1.8 ratio rockers)
Comp LSL/LXL lobes 54-000-11 3 bolt cam core
Cam Valve Events 0.006 0.050 0.200
Intake Duration – ID 281 231 154 13018R LSL lobe .653"
Exhaust Duration – ED 298 246 166 13163R LXL lobe .652"
Lobe Center Angle – LSA 115 115 115
Intake Centerline – ICL 112 112 112
Intake Valve opens – IVO 28.5 3.5 -35 BTDC (- indicates ATDC)
Intake Valve closes – IVC 72.5 47.5 9 ABDC
Exhaust Valve Opens – EVO 87 61 21 BBDC
Exhaust Valve Closes – EVC 31 5 -35 ATDC (- indicates BTDC)
Exhaust Centerline – ECL 118 118 118
Overlap 59.5 8.5 -70 degrees
Old 08-26-2012, 06:03 PM
Tainted's Avatar
thats a whole lotta lift and a big *** split. thats not gonna drive stockish i can tell ya that
Old 08-26-2012, 06:10 PM
ringram's Avatar
I have a 227/243 LSR in my 438 and it drives better than stock. I can run in 6th at 40mph and 5th around 35mph in town no issue. It pulls from a stop in 3rd at 800rpm.
I would run the 231/247 comp if I ever needed a rebuild. The LSA is ok IMO. Tighter will lope more, but the extra durations will do that anyway. It looks good to me
With a good tune I recon it will be "close" to stock.
Go for it
Old 08-26-2012, 06:18 PM
Slash8915's Avatar
Don't know if you know who Patrick G is, but he's the one doing the tune.
Old 08-27-2012, 08:43 AM
Tainted's Avatar
pat G is fantastic. Just know with thatcam you are gonna be replacing springs fairly often and you will need to keep a close eye on that. It should be a good cam, but I think there are some better choices out there. Pat G can also spec you out a custom cam as well, might be worth it especially if hes the one doing the tuning.
Quick Reply: Is this a good cam for a DD?
