Oil pickup question
Old 10-16-2012, 08:38 PM
towerhand's Avatar
Default Oil pickup question
Just installed my oil pan on my new 408. I had to use shims to shim my windage tray, didnt really think about it at the time but i also shimmed my oil pickup tube, The thickness of the shims was 175 thousands, roughly a 1/4 inch. Should this be sufficient clearance between the oil pan and pickup tube, I know its not hitting the oil pan without the gasket in place, really dont want to pull the pan back off unless i need to. The pan is a stock 02 t/a Fbody, ls1 pan and pickup tube, any help will be greatly appreciated.
Old 10-16-2012, 09:58 PM
litle88's Avatar
roughly a 1/4 in clearance without gasket? Your good to go!! Run it.
Old 10-16-2012, 11:41 PM
Peddero's Avatar
1/4 inch pans would be great for you you don't need to do any further experiments on it be on this only
Quick Reply: Oil pickup question
