should i add more pressure?
Old 11-21-2012, 10:39 AM
bugy's Avatar
Question should i add more pressure?
should i add more pressure to valve springs when boosting an engine? cam is supposted to work with 140 lb. how much pressure should i add, pro-charger will boost 14psi, into a 408ci
Old 11-21-2012, 11:25 AM
Brian Tooley Racing's Avatar
I would add 10-20 lbs on the seat. Which lobes does your cam have? Which heads do you have? Do you know the intake valve weight? Stock rockers?
Old 11-23-2012, 02:03 PM
bugy's Avatar
roller lobes, L92 ported heads, stock rockers and about int valve weight they're steel ones, don't know weight.
Quick Reply: should i add more pressure?
