5.3 with ls1 crank
Old 12-12-2012, 12:54 AM
lowrolr's Avatar
Default 5.3 with ls1 crank
If i use a true ls1 crank what acesory brackets should i use. This is going into a 01 blazer. Also i have heard that threar main seal is different. Is there a fix for that issue. Thanks for any help you guys may be able to provide
Old 12-12-2012, 02:06 AM
bww3588's Avatar
Same crank. It will need balanced though. Accessories make no difference, but they all need to match. I.e, you can't use an f body crank pulley with truck accessory brackets.
Old 12-13-2012, 02:38 AM
lowrolr's Avatar
Thanks for the info.
Old 12-13-2012, 02:39 AM
lowrolr's Avatar
Thanks for the info
Quick Reply: 5.3 with ls1 crank
