milling my heads
Old 01-24-2013, 10:13 PM
brokenbird's Avatar
Default milling my heads
How much can I mill my heads before I run into issues with my intake not fitting/bolts not lining up?
Old 01-24-2013, 10:16 PM
miguelc's Avatar
I have done 50 thousands .. but I dont kno about valve-piston clearance, cam was very mild
Old 01-25-2013, 10:00 PM
MASS seller approved
low2001gmc's Avatar
ive heard of .045 but id rather be on safe side and go maximum of .030. when i say safe side, i am referring to not only intake sealing issues but ptv issues. you can always go .030 and try some cometics .040 head gaskets.
most important to remember is once you take off you cant add back to heads. sure you could run thicker than stock gaskets but i wouldnt.
Old 01-25-2013, 10:56 PM
brokenbird's Avatar
I should have plenty of ptv my srp's have a pretty big valve reliefs
Old 01-28-2013, 01:29 PM
low2001gmc's Avatar
what block, flat or dish piston, what heads, what compression you trying to accomplish? the answers to the above questions would help provide more accurate and definitive answers. here to help. feel free to pm....
Old 01-28-2013, 03:51 PM
africangoat's Avatar
more info plz
Old 01-28-2013, 09:34 PM
brokenbird's Avatar
Its a ls2 with dart 225cc with srp pistons and. 2.08 valve I'm not worried about ptv and I'm to get over 11 to 1 if I can
Quick Reply: milling my heads
